10-27-2006 11:22 AM - edited 07-03-2021 01:09 PM
I'm trying to setup WLSE using MS IAS for domain user authenticaion but no luck getting it to work. Is there any good source for configuration procedure?? Below is a list of the components I had for setup please notify me if there are any other components required:
MS Active Diretory Server
Cisco WLSE 2.12
MS IAS (Radius)
Cisco Aironet 1200 APs
10-31-2006 04:39 AM
Hi jason,
yes there is a good source:
EAP Authentication with RADIUS Server
Of course this example uses the Cisco ACS as Radius. But at the bottom there are links to MS as well.
If you want to use PEAP for your WLAN try this one here:
Protected EAP (PEAP) Application Note
And again the ACS is used. Try the links from the above mentioned page to get the MS related information.
I hope that helps.
Best regards,
Frank
P.S. Please rate helpful posts
10-31-2006 10:37 AM
Thank you, I will look into it and try it out.
