Connection between 5508 WLC and 3750-24PS switch
I have to realize a connection between  an 5508 WLC and 3750 switch using one SFP cable. I found on Cisco documentation some reference about two different SFP cables.
The first one is CAB-SFP-50CM, but this is used to interconnect two 3560 switches.
The second is SFP-H10GB-CU1M. This one has SFP+ transceivers on both ends which I don’t know if are compatible with the standard SFP ports that can be found both on WLC and switch.
My question is if I can use one of these cables in order to connect my devices, or if you know other one piece SFP cables.
Many thanks
Hall of Fame Super Silver
Re: Connection between 5508 WLC and 3750-24PS switch
You need an SPF (glc-t) for example.
Sent from my iPhone
-Scott
I know that you can use those SFP transceivers, but I want to know if someone tried to use the SFP-H10GB cables for this kind of connection. Because I saw on another vendor website that the SFP+ cables are compatible with standard SFP ports, and I wanted to see if it is the same for Cisco cables too.
It is not supported.
Sent from my iPhone
-Scott
Hall of Fame Super Gold
The WLC 5508 will only negotiate to 1Gb and nothing more, nothing less.  So you don't need SFP+.
919
