Constant dropping of Access
willb0033
Model E2000
Firmware: 1.0.04
Using 2.4 channels
All devices that are connected wireless through this access point have the difficulty of dropping internet momentarily. When ping from wireless devices to comcast.com with -t I get:
https://lh4.googleusercontent.com/-wdjkBF55Igk/TyoWjPjhEmI/AAAAAAAABb0/kjzMAVVeUuw/s800/Capture2.JPG
This happens about once every minute. Wireless connection itself does not drop just access to the web. Every single wireless device does the same thing including Ipad, ipod, mac and windows machines.
Two machines that are directly wired into the router do not have this problem. Thier Ping status stay at around 60ms.
Things I have tried:
adjusting MTU
Beacon interval in both faster and slower directions
Fragmentation threshold
RTS threshold
Made sure no other devices in range are on same channel
firmware updates
different security settings
changing SSID
Is there anything else I can try to help cure this problem? This is causing streaming problems for both security cameras and client music.
ERIC BARNETT
With that "General Failure" message happening on every device, I would say that your AP has got a radio issue.  Even if it's not showing "down" as such.  The only time I've ever seen that in the wired space is when an ethernet port was flaky.  Try a different AP.
Eric
