Community Member
Converting AP 1242 from Standalone to LWAP mode
hello GS,
Can any one please tell me how to convert Access point 1242 from standalone / infrastructure mode to LWAP mode.
I am not able to intergrate these with my Controller 2100 .
Ap1242 details below:-
DH_3750_SWITCH_STACK#sh cdp nei fa 3/0/21 detail
Device ID: ap
Entry address(es):
IP address: 10.120.249.3
Platform: cisco AIR-AP1242AG-E-K9 , Capabilities: Trans-Bridge IGMP
Interface: FastEthernet3/0/21, Port ID (outgoing port): FastEthernet0
Holdtime : 129 sec
Version :
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.3(8)JEA2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 17-Jul-07 23:02 by ccai
Mirza.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: Converting AP 1242 from Standalone to LWAP mode
Hi Mirza,
You have two options.
One, convert to Autonomous and re-convert back to LWAPP.
Two, the command is "disabled" because you are already running the LWAPP image. Your LWAP contains two IOS images: One has the prefix of "rcv" and the other is the image downloaded from the WLC. Delete this image, let the AP boot the "rcv" image and run the command again.
Hall of Fame Super Red
Hi Mirza,
Here are two good related docs;
Upgrading Autonomous Cisco Aironet Access Points to Lightweight Mode
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp176272
LWAPP Upgrade Tool Troubleshoot Tips
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072d9a1.shtml#prob
Hope this helps!
Rob
Community Member
Hello Rob,
Thank you for the above notes , they been very useful so fat.
Is this the format for AP information file which will be provided in Upgrade tool ?
ap-ip-192.168.200.2,telnet-cisco,telnet-cisco-Cisco,enable-Cisco
or
192.168.200.2,cisco,Cisco,cisco
Also how to upgrade 2100 5.1.185 version software as i see under WLAN option after creating SSID its not showing all its L2,L3 security features.
Is it some bug in this OS.
Can i use 2100WLC for LWAP 1242 series?
Mirza.
2100 does support 1240 series as per the release notes:
http://www.cisco.com/en/US/docs/wireless/controller/release/notes/crn511630.html
Community Member
Hello All,
I am still stuck-up at Upgrading tool ..as the screen says validating user input fields.
I have attached the below data in text file.
ap-192.168.200.2,telnet-cisco,telnet-cisco-Cisco,enable-Cisco
I have assigned 192.168.200.1 for PC and 192.168.200.2 for AP.
Can anybody let me is it correct..why it is not going beyond
Mirza.
Community Member
Hello All,
Finally i am able to convert AP from Standalone to Lwap mode using Upgrade tool, but after connecting it to switch and assigning under vlan 249 on a fast ethernet port
it joins the Controller and disjoin the
Controller .
Observed the below erro:-
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.25! )
*Mar 1 00:00:39.049: %LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CIS
CO-LWAPP-CONTROLLER
*Mar 1 00:00:39.049: %LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolv
e CISCO-LWAPP-CONTROLLER
*Mar 1 00:00:39.050: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:39.534: Logging LWAPP message to 255.255.255.255.
%SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 started - CLI init
iated
%CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
%LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
%LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
%LWAPP-3-CLIENTERRORLOG: Discovery Timer: found the discovery response from mast
er controller
%LWAPP-5-CHANGED: LWAPP changed state to JOIN
ap#s
%LWAPP-3-CLIENTERRORLOG: Join Timer: did not recieve join response (controller -
DHCC_B64_DGFC)
%LWAPP-3-CLIENTERRORLOG: Set Transport Address: no more AP manager IP addresses
remainh run
%SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET JOIN
RESPONSE.
%LWAPP-5-CHANGED: LWAPP changed state to DOWN
I am attaching the error log instance for your reference.
Please advice.
Mirza.
Community Member
Hello GS,
Can you please answer my above query.
Mirza.
Hi Mirza,
Console into the AP in question and go into enable mode.
I am presuming that the AP has a valid IP address and can ping the Management IP address of the WLC. Enter the command lwapp ap controller ip address .
Hope this helps.
Community Member
Hello Leo,
Let me please try this command..my AP problem is it is loading with the new IOS after putting into the relevant vlan after every 2mins .
I want to upgrade my 2100 WLC IOS from current 5.0.148.0 to a standard one , can u suggest me the procedure.
Mirza.
Community Member
Hi Mizra,
The Join process is failing because you are not reeving the join response from the virtual interface on your controller. I ran into the same problem sometime back and it was caused by a firewall which was in between the wireless controller and the AP.
Please refer to the below doc for other possible causes
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
cheers,
Janesha
Community Member
Hello Janesha,
Surprisingly there is not vlan between WLC and AP.
Router is assigned a scope of 10.120.249.0
with a sub interface gi 0/0.249 created with ip address 10.120.249.1.
on switch is vlan249 is assigned to the AP.
Hence no firewall...
But here my AP joins the WLC as u see in the logs and then reboots and relaod the image and then disjoins from the image.
Mirza.
Community Member
Let me clarify few things.Since you have mentioned about a scope I believe you are talking about a DHCP scope.If you are using DHCP can you confirm whether option 43 is configured under DHCP pool on the router?
Community Member
yes option 43 is configured on Router .
ip dhcp pool DGFC_AP
network 10.120.249.0 255.255.255.0
default-router 10.120.249.1 255.255.255.0
option 43 ip 10.120.249.7
one existing Ap which is already in Lwap Image has joined the controller with out any issue.
while converting my AP standalone to LWAP i have configured fa 0 interface ip add as 192.168.200.2 which i am not able to remove ..as my AP joins the controller and then disjoins then relaod and load IOS and then join,disjoin.
I am using the the below IOS for AP1242 -
"c1240-rcvk9w8-tar.123-11JX1"while upgrading using Upgrade tool.
Is this IOS having any issue.
I have tested this AP on a other live production another WLC 2100 ..its behaving the same.
Pleas see the logs below -
ap#lwap ap ip add 10.120.249.4 255.255.255.0
ERROR!!! Command is disabled.
ap#lwap ap ?
controller lwapp primary controller
hostname Configure ap hostname
ip lwapp ap ip command
log-server Configure the syslog server where all LWAPP errors will be logged
ap#lwap ap ip ?
address Configure ap static IP address
default-gateway Configure Default-gateway IP address
ap#lwap ap ip def
ap#lwap ap ip default-gateway 10.120.249.7
ap#lwap ap controller ip address 10.120.249.7
ap#
Translating "CISCO-LWAPP-CONTROLLER"...domain server (255.255.255.255)
*Mar 1 00:00:38.414: %LWAPP-3-CLIENTEVENTLOG: Performing DNS resolution for CIS
CO-LWAPP-CONTROLLER
*Mar 1 00:00:38.414: %LWAPP-3-CLIENTERRORLOG: DNS Name Lookup: could not resolv
*Mar 1 00:00:38.415: %LWAPP-5-CHANGED: LWAPP changed state to DISCOVERY
*Mar 1 00:00:38.894: Logging LWAPP message to 255.255.255.255.
iated
I was suspecting this 2100WLC IOS which is Software Version 5.0.148.0 , but now since i chked this on 2100 WLC Software Version 4.1.171.0 ..the AP behaving the same
Now i feel can isolate any issue with WLC ...
Can any issue with IOS am using for conversion AP from standalone to Lwap?
Please suggest
Hi Mirza,
You are confusing me. What is your issue? Is it your AP not joining the controller or you need assistance in upgrading to the new firmware?
Community Member
Hello Leo,
My AP is not joining the Controller.
Please see the logs below-
CO-LWAPP-CONTROLLER
iated
AM i using the right IOS for conversion of AP from Standalone to Lwap for Ap 1242
"c1240-rcvk9w8-tar.123-11JX1" ?
I have put some more information in my above post .
Thanks for all your support so far.
Mirza.
Community Member
Hello GS,
My AP was just able to join Controller once and showed it is able to join the controller and have received the IP from router and the same had reflected in Controller also.
But after reconnecting to the same fast Ethernet of switch ..again it is giving the same above posted errors.
Note:- When i am connecting a new pre-configured Lwap AP to the same Interface of switch it is joining the controller with out any issue which isloate any issue from network side.
I am having a doubt whether the AP which i have converted from standalone mode to LWAP is purchased with that license?
How do i get more information on this.
For option 43 in router i even tried giving the below command
option 43 hex f104.0a78.Ff97 in place of option 43 ip 10.120.249.7.
Appreciate all your support.
Mirza.
Hi Mirza,
Did you try the command in my previous two post?
Community Member
Hello Leo,
I tried the your command
lwapp ap controller ip address , but it was showing command restricted.
I tried all the possible commands with Lwap ap ip add ....all related commands.
Can you suggest any other?
Mirza.
Community Member
Hello Experts,
Can somebody suggest me some advise for my issue.
Mirza.
Hi Mirza,
Community Member
Hello Leo,
Thank you so much for your efforts, finally my issue has been resolved after following the second method.
Mirza.
Hi Mirza,
We are happy to see that your issue has been resolved and thanks you for the rating.
3941
