03-07-2008 07:36 AM - edited 07-03-2021 03:30 PM
Well, here's My friday problem..I tried to upgrade the IOS on Ap1231's and 2 of them gave me bad results. The first, is running the IOS in memory but didn't copy the config to the flash. So the http, https doesn't work and I don't know how to get the bin file onto the ap.
The 2nd AP is corrupted and is now at the ap prompt. I'm figuring there's a way through the serial port but can't find any info on the site.
Can anyone help, it's a mystery to me as to why upgrades are always a cross your fingers kinda thing with these 1200 series AP's.
Jeff
Solved! Go to Solution.
03-07-2008 08:37 AM
Hi Jeff,
Good fun for a Friday :)
Can you try this method?
Reloading the Access Point/Bridge Image (Edited to fit)
Using the CLI
Step 1 Open the CLI using a Telnet session or a connection to the access point console port.
Step 2 Reboot the access point by removing power and reapplying power.
Step 3 Let the access point boot until it begins to inflate the image. When you see these lines on the CLI, press Esc:
Loading "flash:/c1310-k9w7-mx.v122_13_ja.20031010/c1310-k9w7-mx.v122_13_ja.20031010"
Note Depending on the terminal emulation software you are using, you may have to press Esc twice to access the boot loader.
Step 4 When the bridge: command prompt appears, enter the set command to assign an IP address, subnet mask, and default gateway to the access point.
Note You must use upper-case characters when you enter the IP-ADDR, NETMASK, and DEFAULT_ROUTER options with the set command.
Your entries might look like this example:
ap: set IP_ADDR 192.168.133.160
ap: set NETMASK 255.255.255.0
ap: set DEFAULT_ROUTER 192.168.133.1
Step 5 Enter the tftp_init command to prepare the access point for TFTP.
ap: tftp_init
Step 6 Enter the tar command to load and inflate the new image from your TFTP server. The command must include this information:
the -xtract option, which inflates the image when it is loaded
the IP address of your TFTP server
the directory on the TFTP server that contains the image
the name of the image
the destination for the image (the access point Flash)
Your entry might look like this example:
ap: tar -xtract tftp://192.168.130.222/images/c1310-k9w7-tar.122_15.JA1 flash:
Step 7 When the display becomes full the CLI pauses and displays --MORE--. Press the spacebar to continue.
extracting info (229 bytes)
c1310-k9w7-mx.122-15.JA1/ (directory) 0 (bytes)
c1310-k9w7-mx.122-15.JA1/html/ (directory) 0 (bytes)
c1310-k9w7-mx.122-15.JA1/html/level1/ (directory) 0 (bytes)
extracting c1310-k9w7-mx.122-15.JA1/html/level1/appsui.js (558 bytes)
-- MORE --
if you do not press the spacebar to continue, the process eventually times out and the access point stops inflating the image.
Step 8 Enter the set BOOT command to designate the new image as the image that the access point uses when it reboots. The access point creates a directory for the image that has the same name as the image, and you must include the directory in the command. Your entry might look like this example:
ap: set BOOT flash:/c1310-k9w7-mx.122-15.JA1/c1310-k9w7-mx.122-15.JA1
Step 9 Enter the set command to check your bootloader entries.
ap: set
BOOT=flash:/c1310-k9w7-mx.122-15.JA1/c1310-k9w7-mx.122-15.JA1
DEFAULT_ROUTER=192.168.133.1
IP_ADDR=192.168.133.160
NETMASK=255.255.255.0
Step 10 Enter the boot command to reboot the access point. When the access point reboots, it loads the new image.
ap: boot
Hope this helps!
Rob
03-07-2008 08:37 AM
Hi Jeff,
Using the CLI
ap: tftp_init
-- MORE --
ap: set
ap: boot
Hope this helps!
Rob
03-07-2008 11:40 AM
Thanks for the response Rob.
Yep, tried that and the one with the ap prompt just loads whatever is the boot IOS. So I got that going for me. When I do a dir flash: there is nothing on either one for an IOS image. So, I'm thinking if the 1st loads it will be at ap prompt with just bootloader image.
Hopefully, like switches there's a workaround to find a bin file to put on and upload through the serial port, similar to what you sent Me.
Yeah, this is making my day. So thinking 1010's right now,
Jeff
03-11-2008 09:11 AM
Ok..I figured out how to get the .bin file onto the access point(serially..1hr and some), but now the HTTP part needs to get there and I can't figure out how to get it onto the AP. Any ideas or help is greatly appreciated.
Jeff
