Community Member
CPI 1.3 - unpositioned AP's
Cisco Prime Infrastrucure 1.3 - for a particular map, I have a list of AP's not positioned on the map.  How do I get those on the map?  I see the list but no method to position them.
Hope this link help youhttp:/
http://www.cisco.com/c/en/us/td/docs/wireless/ncs/1-0/configuration/guide/NCS10cg/maps.html
Community Member
Scott,Are you referring to
Scott,
Are you referring to the select a command --> add access points?  I did that initially and selected my AP's.  Then they show in the top right corner of the map. There was a total of 9 and I was dragging them to the correct locations but only was able to move four of them. It is like the other 5 disappeared.  So now I have the message Unpositioned Access Points are not shown on map. Click Here to see Access Points added but not yet positioned.  I do that and they show up at the bottom as a List of APs not positioned on the map.   I don't see how I get those to show up on the map so I can place them on the map.
Hall of Fame Super Silver
There is a drop down on the
There is a drop down on the top right side when you are in the floor you want to make changes to.  There you can choose to add access points or re-position access points.
-Scott
105
