Community Member
create a template with 4 SSIDs WLSE 2.12
When i create a template with 4 SSIDs, it adds the 4th one to the ssid table, but when i try to save or go to another menu , it displays a blank screen.
i can save till 3 SSIDs but, with the 4th one it bugs.
I have done the same test with WLSE 2.11 and i have no problem.
Is there any suggestions ?
1 REPLY
Community Member
Re: create a template with 4 SSIDs WLSE 2.12
I have two possible solutions (allthough not verified or tested):
Use the custom section in templates for all of the fourth SSID;
Upgrade to WLSE 2.13;
Bas Kokken
164
