Creating SSIDs in different APs.. Cisco Controller 5508 SW 7.5.102.0
I'm planning to create an SSIDs for different purpose, but when I create the SSID, I can see it on all the APs..
In other words, I have 2 floors and i want to differentitate access points on floor wise basis. 1st floor ap should broadcast only SSIDF1 and second floor ap should only broadcast SSIDF2 . I have made access point groups but both SSID's are being broadcast on all access points in 1st and 2nd floor.
Any help?
Hussain
1 ACCEPTED SOLUTION
VIP Purple
HI Hussain,
If you want to specfy which SSID should broadcast from which AP then u can create AP groups.
Yes you can have all SSID's, some and only one SSID if you want.  The purpse of AP groups is to allow you to choose what AP's will have what SSID's.
How to create and implement AP groups then plz use this:
http://mrncciew.com/2013/05/30/configuring-ap-groups/
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
Dont forget to rate helpful posts.
VIP Purple
HI Hussain,
Hi Sandeeb,
Thank you very much for your prompt response, I will check out the links provided and let you know how it goes.
Appreciated.
248
