Hi all,
I have an exisiting Pt to Multipoint network of 1410 bridges. Connected to each bridge is a 1200 AP. I want to put the clients on one VLAN and the "equipment" on another VLAN.
I think I understand that you have to configure both interfaces on each device, starting with the furthest away device finally doing the root bridge last.
Instead of using the GUI to configure I am going to use the CLI. What I want to know is if I use the CLI and give the commands including a new SSID will I lose contact with the radio after I issue the command but havent finished the config?
I want to do this from the NOC and avoid serious ladder work.
Kim
