Critical Alarms from LAPs in Maintenance State
Should a critical alarm be triggered when an LAP disassociates from a WLC if it is placed in Maintenance State before it's taken offline?
Should I delete, clear or acknowledge the critical alarm if a LAP was taken offline before it was placed in Maintenance state?
Should I still put LAPs in maintenance state if they were taken offline before I had a chance to?
Using Cisco Prime Infrastructure version 1.2
Everyone's tags (3)
are you hitting the below bug
are you hitting the below bug?
https://tools.cisco.com/bugsearch/bug/CSCug80248
Seems like it.  Would you
Seems like it.  Would you suggest that I open a case or signup for updates about the bug?
nevermind.
I just upgraded CPI to
I just upgraded CPI to version 2.2 and the controllers to 7.6.130 and I'm still getting the same result.
I'm getting critical alarms for APs in Maintenance State.
49
