11-14-2006 12:01 PM - edited 07-03-2021 01:14 PM
I am basically trying to take the e-mail pass-through page and manipulate the simple html code say Signature instead of Email Address. However Every time I copy the code and open up the login.html that I upload with the custom webauth page I no longer have a submit button and even when I hit enter it no longer redirects me anywhere. Basically the need for this is to have the users name in the system to log them. We are just trying to figure out if there is a way for a guest to self register themselves by reading a license agreement and then signing at the bottom. Thanks in advance for any help that could be provided
11-14-2006 03:18 PM
Yes, you can do this. When you are manipulating the code, are you removing any of the java scripting?
11-15-2006 04:57 AM
No I am keeping all the scripting there. I basically copy the source from the e-mail webauth page and make one minor change that changes the line Input Email to Signature. Even if I don't change a thing the submit button doesn't show up. I will attach the html page to give someone a better understanding of what is going on.
11-16-2006 12:10 PM
ok, when you are uploading, are you just uploading the HTML file or a tar archive that thas all the files?
11-17-2006 08:45 AM
I Tar the file first which does work without a problem.
