Design of wireless solutions with WLC 5508
ganfossi
There is a recommendation by Cisco of the minimum number of gigabit ports, which is to be installed by the amount of AP associated with a controller 5508, for 150 AP is associated with a driver, you must install at least 3 gigabit ports?
Please, we need this information to design a solution.
Best regards.
Giovanni Anfossi
Tiago Antunes
From the config guide Cisco 5500 series controllers have no  restrictions on the number of access points per port, but Cisco  recommends using LAG or multiple AP-manager interfaces on each Gigabit  Ethernet port to automatically balance the load:
http://www.cisco.com/en/US/docs/wireless/controller/6.0/configuration/guide/c60mint.html#wp1277659.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Thanks, this information help I need.
