DHCP Problem behing WGB1200 (vlans)
I have a problem with an installtion, where i have a br1300 with 2 vlans and on both vlans are wgb1200 connectect (no trunk there!)
in the native vlan the clients behind the wgb gets ip addresses but not clients behind the wgbs in the 2nd vlan. i have helper addresse and so on i im on the switch where the br1300 (trunk) is connected i get an ip from both vlans so the vlans are correct!
the WGB in the 2nd vlan workes fine im also able to connect to the wgb but the clients behind dont work?
help
Bernhard
1 REPLY
Silver
Re: DHCP Problem behing WGB1200 (vlans)
When configuring native VLANs always ensure that the native VLAN settings match on the Switch trunkport and the AP or any other wireless device. Otherwise some part of the WLAN will not work.
114
