DHCP WLAN 1240AG
I want to enable the DHCP server on the 1240AG. I only want to give IP addresses to clients who connect on the 802.11g radio interface and not on the 802.11a radio interface or the Ethernet interface. Is this possible, if so how?
(As a compromise I would be satisfied just to deny client's IP addresses who connect from the Ethernet interface and allow both radios.)
Thanks.
1 REPLY
Silver
Re: DHCP WLAN 1240AG
I think you can enable one radio interface at the same time you can disable the another radio interface on the 1240AG. More info about DHCP configuration.
Configuring DHCP Option
http://www.cisco.com/en/US/docs/wireless/access_point/1240/installation/guide/124h_g.html
335
