Disable LEAP for Wireless Client authentication.
vramanaiah
In our setup, we have APs coonfigured with LEAP to do authentication with WLSM, for WDS functionality..
We also have an SSID where PEAP is configured for client auth.
Obviously, the ACS is configured to support both LEAP and PEAP for the above requirements.. but now the problem that i have now is that with the same SSID that uses PEAP, users can connect using LEAP and get connected to the network..
Now, how do i disable LEAP for end user authentication (Wireless clients). I would like to use LEAP only for AP Authentication.
jhudson
Look for this line in your WDS accespoint-
wlccp authentication-server client leap method_"Your Server Group Name" and get rid of it by using the command -
no wlccp authentication-server client leap method_"Your Server Group Name"
* "Your Server Group Name" will be whatever you named your client authentication server group.
