Disable SSID broadcast on Aironet 350
I only have four clients to this access point, which I have hard coded the SSID on to them. I want to keep programs like NetStumbler from knowing the AP is there. I have WEP, TKIP, and MIC installed for security I just figure if you can keep someone from knowing that an AP exists you have won half the battle. Is this possible?
Tim
Re: Disable SSID broadcast on Aironet 350
Turning on broadcast SSID on AP allows AP to send SSID in beacon packets .
Beacon is like keepalive packets . Clients like XP , searches for any wireless
network in nearby area to connect to it . So for such clients it is useful to turn
on broadcast SSID . I guess your dlink also worked on same principle and got connected .
As SSID is transmitted in every beacon it is consider as security risk and document suggest not to turn on broadcast ssid .
SSID is NOT for security reason although many people consider ssid as security measure .
Even you turn off broadcast ssid in beacon packet by turning off ssid on ap ,
probe request and proble response will always contain the SSID . there is no
way to hide the ssid .
You can reduce the coverage area ( or cell ) by reducing the transmitt power .
This is also one of the security step .
Nilesh
I use the WEB to mange my AP 350s, if you use the WEB interface go to AP350 Radio Hardware page and you will see a line "Allow Broadcast SSID to Associate" with a radial button for yes or no. Select no will stop the AP from broadcasting the SSID.
Gary
Thanks for your reply Gary
I have that feature turned off, but it still does it.
619
