DMVPN dual hub - QoS preclasify limitation
Reading the DMVPN design guide I found: "qos pre-classify is not supported in an architecture that implements two different headends for mGRE tunnels and VPN tunnels."
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns171/c649/ccmigration_09186a008075ea98.pdf
Currently i am using a single headed DMVPN design with qos preclasify configured on the hub and voice works just perfect. My concern is with regards to implementing  a secondary hub for redundancy. How will the qos be handled if the qos preclasify is not supported?
  • Security and Network Management
Everyone's tags (7)
1 REPLY
I think you need to move the post to the correct forum. I think you wanted to post it in Security forums while this security part is under wireless forums so it only talks about wireless related security.
You need to move your post to the correct sub-forum under Security main forum.
Glad though to see you here in our forum part
Good luck.
Amjad
Rating useful replies is more useful than saying "Thank you"
293
