Do somebody knows the Correct Deployment CoA With ISE wired and wireless?
   At this time we have some problems with a lab about ISE and Wired-Wireless network.
We try to do CoA like dot1-->MAB-->GuestWeb.
And for example when dot1x device authetication fails go to MAB and the authentication is ok when the device is on whitelist, we can see the acl applied on the device from the switch, however, when we try to authenticate with a device out the white list we can´t make the web authentication from ISE appears no authenticate the device doing CoA, all this from wired environment.
Do somebody knows if this deployment is valid or functional, and if we try to add the same wireless environment it will function?
We have so much days trying with this even we have an open TAC case and it doesn´t works.
Thank you for your help and support.
1 REPLY
Bronze
Re: Do somebody knows the Correct Deployment CoA With ISE wired
I don't think we can bind mab with 802.1x as wired do.
245
