Does Air 350 PC card support WPAPSK??
I've got a Air-PCM352 card on my laptop.
It works great w/ WEP, but when I try to make it work w/ WPAPSK w/ either TKIP or AES, I don't get any option for WPA at all.
I'm using Aironet Client Utility v5.01.
Does this card support WPA? If so, how can I get it to work?
350 series are discontinued and I can't find a driver download site for it.
Re: Does Air 350 PC card support WPAPSK??
AIR-PCM352 supports WPAPSK/TKIP
It may be EOL, but it doesn't mean it is EOS.
You should be able to get latest Rev at:
http://tools.cisco.com/support/downloads/go/Platform.x?softwareType=Aironet%20Client%20Bundle%20(Firmware,%20Driver,%20Utility)
For XP Exmaple:
PCM, LMC, PCI Client Adapter firmware 4.25.30, Windows XP NDIS driver 8.2.3, ACU 5.05.001
If you have problems getting the file, I'd suggest opening a TAc case (have your NIC's SN handy).
Thank you for the quick response.
I downloaded the bundle at the link you provided, and now have ACU v5.05.001 and driver v.8.3.10.0.
I still don't see the option for WPA in either ACU or Windows zero config - I only get Open or WEP as security options.
Am I missing something else here?
305
