Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Does EAP/SIM make sense for others than mobile operators?
I'm wondering about the many different EAP authentication protocols. One of these is EAP/SIM (initiated by Nokia). I think the advantage of this authentication method might be the kind of key exchange. Users are familiar in using SIM-cards. Out of this consideration I have some questions:
* Is EAP/SIM as secure as EAP/TLS or EAP/Cisco?
* Does it make sense to use EAP/SIM as an WISP (given that the WISP is NOT a GSM/UMTS mobile operator)?
* What is the position of Cisco to EAP/SIM? Will Cisco support it?
Best regards,
Armin
1 REPLY
Bronze
Re: Does EAP/SIM make sense for others than mobile operators?
287
