Community Member
DSL to ASA5510
I am brain dead when it comes to security for some reason. I have an ADSL Zyxel router plugged into an ASA 5510 and I am trying to do a simple translation:
DSL -> 84.12.169.200 Zyxel DSL Router PPoA 192.168.100.9 - > 192.168.100.10 ASA 5510
I am simply trying to sent port 443 to IP address 10.100.3.21 located on the inside interface, but it is not working. I have tried various combinations using the 192.168.100.9 and public address. What am I doing wrong?
Result of the command: "show run"
: Saved
ASA Version 8.0(4)
hostname ICD-PG-ASA-01
domain-name icdt.org.uk
enable password 4NnTfJ8McbjOev2J encrypted
passwd 4NnTfJ8McbjOev2J encrypted
names
name 10.100.3.21 TIM description TIM Server
name 84.12.169.200 PUBLIC_ADDRESS description Port Glasgow Broadband Public Address
name 10.100.3.20 CCM description Call Manager
interface Ethernet0/0
nameif outside
security-level 0
ip address 192.168.100.10 255.255.255.252
ospf cost 10
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.200.3.10 255.255.255.0
ospf cost 10
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.10.1 255.255.255.0
ospf cost 10
management-only
ftp mode passive
dns domain-lookup inside
dns server-group DefaultDNS
name-server 10.210.3.21
name-server 10.200.2.21
object-group network ICDT_Networks
description ICDT Internal Networks
network-object 10.100.0.0 255.255.0.0
network-object 10.200.0.0 255.255.0.0
network-object 10.210.0.0 255.255.255.0
object-group network Mail
description Mail Servers
network-object host 10.210.3.22
object-group service Mail_ports
description Mail Ports
service-object tcp eq https
service-object tcp eq smtp
access-list inside_nat0_outbound extended permit ip 10.200.3.0 255.255.255.0 any
access-list inside_nat0_outbound extended permit ip any 10.80.3.0 255.255.255.0
access-list outside_access_in extended permit tcp any eq https host PUBLIC_ADDRESS eq https
access-list outside_access_in extended permit ip any any inactive
access-list inside_access_in extended permit tcp host TIM eq https any eq https inactive
access-list inside_access_in extended permit tcp any any eq https
access-list inside_nat_static extended permit tcp host TIM eq https any
no pager
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool VPN 10.80.3.50-10.80.3.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-613.bin
no asdm history enable
arp timeout 14400
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
static (inside,outside) tcp PUBLIC_ADDRESS https TIM https netmask 255.255.255.255
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
router ospf 1
network 10.200.3.0 255.255.255.0 area 0
network 192.168.100.8 255.255.255.252 area 0
area 0
log-adj-changes
default-information originate metric 1
route outside 0.0.0.0 0.0.0.0 192.168.100.9 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 10.80.3.0 255.255.255.0 outside
http 10.100.3.0 255.255.255.0 inside
http 192.168.10.0 255.255.255.0 management
http 10.200.0.0 255.255.0.0 inside
snmp-server host inside TIM community icdtrrw
snmp-server location Port Glasgow
no snmp-server contact
snmp-server community icdtrw
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime seconds 28800
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set security-association lifetime kilobytes 4608000
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 10.80.3.0 255.255.255.0 outside
telnet 10.200.0.0 255.255.0.0 inside
telnet 10.1.0.0 255.255.0.0 inside
telnet 10.100.3.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd address 192.168.10.2-192.168.10.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 132.163.4.101 source outside
ntp server 132.163.4.102 source outside
ntp server 132.163.4.103 source outside
ntp server 131.107.1.10 source outside
group-policy VPN_UNRESTRICTED internal
group-policy VPN_UNRESTRICTED attributes
dns-server value 10.210.3.20 10.200.2.20
vpn-tunnel-protocol IPSec
username crawforde password fvFXLK8hmMQ6xycH encrypted privilege 15
username Administrator password sr9nyF6F4pWPyBot encrypted privilege 15
username commsfm password kAu0GvAYo6iGTAg3 encrypted privilege 15
username commsfm attributes
vpn-group-policy VPN_UNRESTRICTED
tunnel-group VPN_UNRESTRICTED type remote-access
tunnel-group VPN_UNRESTRICTED general-attributes
address-pool VPN
default-group-policy VPN_UNRESTRICTED
tunnel-group VPN_UNRESTRICTED ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:a78724a86f26e65b77b359dd1ed780ae
: end
557
