You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Dual client authentication problem in AP1200
I have got an AP1200 with EAP-TLS authentication. I would need to associate a new non EAP authentication device. It supports WEP or MAC authentication. I read that I can only use MAC with EAP-TLS, but I have tried to configure it by adding:
username aaaabbbbcccc password 0 aaaabbbbcccc
username aaaabbbbcccc autocommand exit
aaa authentication login 701 local
dot11 association mac-list 701
dot11 ssid myssid
authentication open mac-address 701 alternate eap eap_methods
authentication key-management wpa
guest-mode
access-list 701 permit aaaa.bbbb.cccc 0000.0000.0000
access-list 701 deny 0000.0000.0000 ffff.ffff.ffff
.....but It does not work. I get the following error:
dot11_auth_send_msg: client FAILED to authenticate aaaa.bbbb.cccc, node_type 64 for application 0x1
dot11_auth_delete_client_entry: aaaa.bbbb.cccc is deleted for application 0x1
%DOT11-7-AUTH_FAILED: Station aaaa.bbbb.cccc Authentication failed
Could you help me, please?
Thanks a lot for your help
Juan Manuel
  • Security and Network Management
Silver
Re: Dual client authentication problem in AP1200
Try a standard access list and have configuration . Just have this configuration access-list 701 permit aaaa.bbbb.cccc
I have tried again the same configuration but this time I configured one ACL entry instead of two (I deleted : access-list 701 deny 0000.0000.0000 ffff.ffff.ffff). Unfortunately I does not work yet.
AP1200 has got the following IOS:
c1200-k9w7-mx.123-4.JA
Perhaps it could be a version problem, could not it?
I have included a debug file.
Thanks for your help
Juan Manuel
313
