Dynamic VLAN-Assignment from RADIUS with Aironet 1242AG doesn't work properly
Hello All,
our setting is to assign VLANs dynamically from RADIUS (freeradius) to Clients connected to the 1242 Access-Points with one SSID. We have Firmware
12.4(10b)JA/JDA on the Aironet 1242.
The clients should be connected to one of three VLANs - one for staff, one for students and one for guests. I use the Web-Interface of
the 1242, because I'm not very familiar with IOS cli.
After assigning the first VLAN to the SSID -> click Accept, assigning the second VLAN to the SSID (overwriting the previous one) -> click Accept,
assigning the third VLAN to SSID (overwriting again) -> click Accept,  the assignment of VLANs works really fine,
(the only thing i change on the page is VLAN, the SSID is set to mandatory WPAv2)
BUT...
when the 1242 is rebooted (due a building power off or similar) it doesn't work anymore. Clients end up in an endless authentication loop.
After doing the procedure again from above - assigning all VLANs sequently once, it works fine again !  till next reboot...
All VLANs have same encryption, cypher, TKIP+AES CCM. On the Cisco-Site I found a command, which i also tried with no success:
'aaa authorization network default group radius'.
I also tried to save the working config and load it into the 1242 again, this also did not work.
It seems that i'm doing something wrong, but what ?
Thanks for some help,
Frank
1 REPLY
Gold
Re: Dynamic VLAN-Assignment from RADIUS with Aironet 1242AG does
All you really need to do is make sure the subinterfaces/vlans are created for each VLAN you need, then have radius push down IETF attributes 64, 65, and 81.
1162
