07-19-2013 07:44 PM - edited 07-04-2021 12:28 AM
Hi All,
I have 300 APs deployed and concurrent client associations that number 3000+ daily
at the moment I have a single subnet for all users, there is no authentication just a click through
page with email entry to gain access.
The APs are assigned to groups based upon the building zone they are in, is it possible to
assign a vlan based upon the AP the user is associated to but still only broadcast a single SSID.
TIA
Solved! Go to Solution.
07-19-2013 11:28 PM
You can assign dynamic vlan for 802.1X authentication using aaa override from RADIUS server.
In your case, since it is webconsent ssid you can use AP groups to put clients on differnt vlans per the AP group
07-19-2013 11:28 PM
07-20-2013 10:26 AM
Thanks I found the relevant document, "http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml"
