dynamic vlan on ISR 8xx and other platforms...
Whether 8xx and ISR platforms can support the dynamic vlan?.SOHO ISRs got the integrated wireless service feature. Anyone has the feature matrix?. Because, We want to implement dynamic host based access for the SOHO users using ISE.
thanks,
Ramesh
Everyone's tags (2)
it supports upto 3 Dynamic
it supports upto 3 Dynamic WEP VLANs
Hi, Tried Dynamic vlan and
Tried Dynamic vlan and dynamic acl. Both are not working.  Users are not moved to a new vlan.
We have cisco 877 running 124-24.T2.
thanks,
Hi, Are you talking about the
Are you talking about the dynamic vlan assignment to the users authenticating against the ISE?
If yes , then that can be done.
Dhiresh
Check the Cisco Identity
Check the Cisco Identity Services Engine Network Component Compatibility "routers"  section
http://www.cisco.com/c/en/us/td/docs/security/ise/1-2/compatibility/ise_sdt.html
33
