Dynamic VLAN/SSID assignment w/IPv6
I have followed the answer in this discussion which instructs on how to get Dynamic VLAN/SSID assignments using WLCs + MS IAS:
https://supportforums.cisco.com/thread/339396
This works great for IPv4.  This does not appear to work for IPv6.
I have CT2504 WLCs running v7.0.116.0 and AP 3502s.  I have a Windows 2003 IAS working for 802.1x authentication using PEAP and per-user/group dynamic VLAN/SSID assignments.  Based on who you authenticate as, you are placed on the appropriate VLAN.
However, IPv6 does not function properly.  I believe this is due to the nature that the WLC only bridges IPv6 from the Interface Group that the WLAN is assigned to and/or whatever Multicast VLAN you assign.
If I connect as a user assigned to the same matching VLAN as the WLAN Interface / Multicast VLAN, IPv6 works just fine.  I do not even have to have the "Enable IPv6" box checked in the Advanced tab, nor does the "Multicast Vlan Feature" need to be enabled - IPv6 still works.
If I connect as a user that is assigned to a different VLAN than the WLAN Interface / Multicast VLAN, I see the IPv6 Router Advertisement from the WLAN Interface / Multicast VLAN, and not the VLAN that "Allow AAA Override" switched me to.  Naturally since I'm getting as IPv6 prefix for a different VLAN, when I try to route traffic through the IPv6 default gateway (which isn't on the VLAN I'm connected to), it doesn't work.
One work-around to have IPv6 support is to use distinct, non-dynamic per VLAN/SSID assignments.  This is ugly and doesn't scale (16 max SSIDs).
Has anyone else experienced this and know of a solution?
For now I'll just have to set the WLAN Interface to a VLAN which does not have IPv6 enabled and my wireless users won't have IPv6 unless they VPN on top of Wifi.  Rather disappointing.
1 ACCEPTED SOLUTION
this sounds alot like another implication of IPv6 with "more than one VLAN on the same SSID".
see this thread:
https://supportforums.cisco.com/thread/2157621?tstart=60
not with dynamic vlan, but vlan select - which, on the L2/L3 on SSID-side is essentially the same.
as mentioned in the thread, 7.2 has a feature that "automatically sends the correct RA to the correct clients via L2  wireless unicast. By unicasting the RA, clients on the same WLAN, but a  different VLAN, do not receive the incorrect RA."
lucky for you, 7.2 is available for the 2504 - with my WiSM1s I am out of luck :-(
so this feature *could* solve this problem, as the problem is that the wrong IPv6-RAs are broadcasted for the client (because the SSID is the same)
see this thread:
Excellent, thank you for the tip.  I downloaded 7.2 last night before I'd left, but did not have time to test yet.
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.2.110.0
Testing with the non-default VLAN shows the correct IPv6 RA for that VLAN is now coming through and IPv6 traffic is worknig as expected.
531
