eap tlas and peap
Dear
How can i configure the both security tls and peap
but first the client must enter the user name and password (peap) then check the tls (certification)
that?s mean using the two way to authentication in the same time
Am already configured the tls and peap but how to add both together that?s not
Thanks in advance
1 REPLY
Re: eap tlas and peap
I'm not sure why you want to have both EAP type. If you set up TLS that is itself two way authentication.
In TLS you install CA on both server and on client, so
Client verify server
Server verify client
~JG
104
