Gold
EAP-TLS and certificate export
Hello we are using EAP-TLS authentication with ACS 3.2 and MS CA...It works fine Now I would like to deploy this solution also in our DMZ for visitors... Problem is that I dont want plug vistiors to our network for certificate install.. Is there any way how to export and than import personal (server side) certificate for vistors?
Thx
M.
Re: EAP-TLS and certificate export
Can you please give more details about your setup ? What kind of access to your network do your visitors need ?
Based on my experience, I do not recommend using certificate for visitors (complex to implement, hard to manage, no added value, requires administrative right on the computer...). Is web authentication not sufficient ?
Rgds,
Gaetan
what type of ca u use..i m trying to do the same for machine authentication using standalone ca and active directory..the best practice is enterprise but standalone ca can be used ..i got it confirmed with cisco-thanx
Gold
Our design is Root CA and Subordinate CA... we enroll certs from subordinate i will try use enroll directly from root..THX
please
can you help me and tell me how can i configured the ACS and install the certification in client and ACS
do i need use interprise root certification and how can i do it
please advice
thanks in advance
308
