EAP-TLS and WEP?
Hello
Are there any security issues with running EAP-TLS and WEP (as in http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_white_paper09186a008009256b.shtml)?
With WEP there are the issue with WEP being crackable. But, when I combine WEP with EAP-TLS, is it still possible to crack WEP or are there some kind of wep key rotation in EAP-TLS?
Jimmy
1 REPLY
Bronze
Re: EAP-TLS and WEP?
I would suggest not to use WEP because WEP is known to have a lot of vulnerabilities. Instead you can use WPA or WPA 2 which uses AES encryption which is considered more secure. You can use EAP-TLS for authentication and WPA 2 and AES for key management and encryption.
244
