EAP-TLS Questions....
Hi all,
My setup is like this..
Laptop - LWAPP - WLC - ACS - AD
I m using CA to generate certificate.. I have configured EAP-TLS on WLC & ACS SE. Everything is working fine ie when i issue a certificate from CA on my AD login name & install that certificate i m able to connect to WLAN.. For security on WLC i have enable WPA & 802.1x...
What i want is that when i boot up the laptop it should directly get connected to Wireless network & whne i try to login using my user name & password it should prompt for if my password is expired or something & get connected to AD. But this is not happening which use to happen when we were using peap as it ask for username & paswword to connect but not in case of EAP_TLS it only check for valid certificates....
Thanks in advance..
regards,
piyush
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: EAP-TLS Questions....
EAP-TLS doesnt use a username/password only PEAP:
http://technet.microsoft.com/en-us/library/cc739638.aspx
-Scott
Hi All,
what i want 2 knw is does EAP-TLS check for password as its credentials or only check for username from AD.
regards,
Piyush
-Scott
Hi Fella,
i had one more issue ie want to do perform machine authentication as the laptops boot up along with the user authentication hen the users logs in.
I had set AuthMode value to 1 for it. But how should i check on my ACS SE that the machine is authenticated or not & is it possible that during login using username & password the WLAN should get connected as it is for ethernet LAN.
Thanks for ur reply..
Piyush
179
