EAP-TLS uses WEP ?
Why do you need to configure WEP as data encryption when using EAP-TLS ?
"Ensure that Data Encryption is set to WEP"
Can't you use WPA2 ?
Gr.
Remco
1 ACCEPTED SOLUTION
Re: EAP-TLS uses WEP ?
Remco,
1. What do I have to do to configure EAP-TLS ??
In order to configure EAP-TLS the only configuration on the WLC is selection of 802.1x on the Layer 2 Security Screen.
2. Users must have a user certificate and the computers need a computer certificate. IAS Server needs a server certificate.
You RADIUS server needs to have a certificate and this needs to be added on each client to the list of trusted certificates. There is no configuration required on the controller side for this.
3. I want to use WPA/PWA2 enterprise with AES encryption. In all the documents you can see that the client is configured with WEP.
By default if you choose 801.x on the layer 2 security, WEp is used as the encryption. You have to understand these are two different things. One is encryption (TKIP/AES and another is authentication 801.x). So if you want to use WPA2 with EAP-TLS, you need to select WPA1+WPA2 as the Layer 2 Security and then select 802.1x on the same screen under "Auth Key Mgmt" select 802.1x
Let me know if this answers your question.
Pushkar
Hall of Fame Super Silver
What device do you have.... WPA or WPA2 is usually the choice... not WEP. Here is a link to EAP-TLS for an WLC.
http://www.cisco.com/en/US/products/ps6366/products_configuration_example09186a00807917a6.shtml#t19
-Scott
Remco,
If you want to use EAP-TLS as the authentication and WEP as the encryption, you need to set the following on a WLAN on the controller.
Under Security ---> Layer 2 in a WLAN, Select "Layer 2 Security" as 802.1x and the "802.1X Parameters" to WEP with the key length you want. You ACS server should be configured to do EAP-TLS. The client should also be configured appropriately.
Pushkar
What I want is this:
A secure wireless network (already did PEAP MS-CHAP v2, but want to try EAP-TLS).
Users must have a user certificate and the computers need a computer certificate. IAS Server needs a server sertificate.
I want to use WPA/PWA2 enterprise with AES encryption...
In all the documents you can see that the client is configured with WEP...
Remco
Remco,
Pushkar
954
