Community Member
error Connecting a WET200 to a Wireless controller
I'm having a problem with a cisco bridge WET200
we have a medical equipment whit fixed IP and it has to connect to a wireless network ... and for that I set up the wireless network ... in this bridge
but the equipment is not communicating with the gateway, with nothing!
WLC always appears the following error:
WiSM-slot9-1) >debug client XX:XX:XX:XX:XX:XX
(WiSM-slot9-1) >*apfReceiveTask: May 23 12:03:27.953: XX:XX:XX:XX:XX:XX Deleting mobile on AP XX:XX:XX:XX:XX:XX(0)
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX Adding mobile on LWAPP AP XX:XX:XX:XX:XX:XX(0)
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX Association received from mobile on AP XX:XX:XX:XX:XX:XX
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX 0.0.0.0 START (0) Changing ACL 'Guest' (ACL ID 0) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1393)
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX Applying site-specific IPv6 override for station XX:XX:XX:XX:XX:XX - vapId 5, site 'default-group', interface 'rispax'
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX 0.0.0.0 START (0) Changing ACL 'none' (ACL ID 255) ===> 'none' (ACL ID 255) --- (caller apf_policy.c:1393)
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX Applying IPv6 Interface Policy for station XX:XX:XX:XX:XX:XX - vlan 29, interface id 9, interface 'rispax'
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX STA - rates (8): 132 139 12 18 150 24 36 48 0 0 0 0 0 0 0 0
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX STA - rates (11): 132 139 12 18 150 24 36 48 72 96 108 0 0 0 0 0
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX Processing RSN IE type 48, length 20 for mobile XX:XX:XX:XX:XX:XX
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX apfProcessAssocReq (apf_80211.c:4553) Changing state for mobile XX:XX:XX:XX:XX:XX on AP XX:XX:XX:XX:XX:XX from Idle to AAA Pending
*apfMsConnTask_0: May 23 12:04:11.109: XX:XX:XX:XX:XX:XX Scheduling deletion of Mobile Station:  (callerId: 20) in 10 seconds
*apfReceiveTask: May 23 12:04:11.110: XX:XX:XX:XX:XX:XX 0.0.0.0 START (0) Initializing policy
*apfReceiveTask: May 23 12:04:11.111: XX:XX:XX:XX:XX:XX 0.0.0.0 START (0) Change state to AUTHCHECK (2) last state AUTHCHECK (2)
*apfReceiveTask: May 23 12:04:11.111: XX:XX:XX:XX:XX:XX 0.0.0.0 AUTHCHECK (2) Change state to 8021X_REQD (3) last state 8021X_REQD (3)
*apfReceiveTask: May 23 12:04:11.111: XX:XX:XX:XX:XX:XX 0.0.0.0 8021X_REQD (3) Plumbed mobile LWAPP rule on AP XX:XX:XX:XX:XX:XX vapId 5 apVapId 5
*apfReceiveTask: May 23 12:04:11.111: XX:XX:XX:XX:XX:XX apfMsAssoStateInc
*apfReceiveTask: May 23 12:04:11.111: XX:XX:XX:XX:XX:XX apfPemAddUser2 (apf_policy.c:222) Changing state for mobile XX:XX:XX:XX:XX:XX on AP XX:XX:XX:XX:XX:XX from AAA Pending to Associated
*apfReceiveTask: May 23 12:04:11.111: XX:XX:XX:XX:XX:XX Stopping deletion of Mobile Station: (callerId: 48)
*apfReceiveTask: May 23 12:04:11.111: XX:XX:XX:XX:XX:XX Sending Assoc Response to station on BSSID XX:XX:XX:XX:XX:XX (status 0) ApVapId 5 Slot 0
*apfReceiveTask: May 23 12:04:11.111: XX:XX:XX:XX:XX:XX apfProcessRadiusAssocResp (apf_80211.c:2041) Changing state for mobile XX:XX:XX:XX:XX:XX on AP XX:XX:XX:XX:XX:XX from Associated to Associated
*dot1xMsgTask: May 23 12:04:11.113: XX:XX:XX:XX:XX:XX Creating a PKC PMKID Cache entry for station XX:XX:XX:XX:XX:XX (RSN 2)
*dot1xMsgTask: May 23 12:04:11.113: XX:XX:XX:XX:XX:XX Adding BSSID XX:XX:XX:XX:XX:XX to PMKID cache for station XX:XX:XX:XX:XX:XX
*dot1xMsgTask: May 23 12:04:11.114: New PMKID: (16)
*dot1xMsgTask: May 23 12:04:11.114:      [0000] c8 bb 79 d0 f3 88 f5 41 91 77 fb de ba 7e e5 f5
*dot1xMsgTask: May 23 12:04:11.114: XX:XX:XX:XX:XX:XX Initiating RSN PSK to mobile XX:XX:XX:XX:XX:XX
*dot1xMsgTask: May 23 12:04:11.114: XX:XX:XX:XX:XX:XX dot1x - moving mobile XX:XX:XX:XX:XX:XX into Force Auth state
*dot1xMsgTask: May 23 12:04:11.114: XX:XX:XX:XX:XX:XX Skipping EAP-Success to mobile XX:XX:XX:XX:XX:XX
*dot1xMsgTask: May 23 12:04:11.114: Including PMKID in M1  (16)
*dot1xMsgTask: May 23 12:04:11.114: XX:XX:XX:XX:XX:XX Starting key exchange to mobile XX:XX:XX:XX:XX:XX, data packets will be dropped
*dot1xMsgTask: May 23 12:04:11.115: XX:XX:XX:XX:XX:XX Sending EAPOL-Key Message to mobile XX:XX:XX:XX:XX:XX
        state INITPMK (message 1), replay counter 00.00.00.00.00.00.00.00
*Dot1x_NW_MsgTask_0: May 23 12:04:11.128: XX:XX:XX:XX:XX:XX Received EAPOL-Key from mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:11.128: XX:XX:XX:XX:XX:XX Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:11.128: XX:XX:XX:XX:XX:XX Received EAPOL-key in PTK_START state (message 2) from mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:11.128: XX:XX:XX:XX:XX:XX Stopping retransmission timer for mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:11.128: XX:XX:XX:XX:XX:XX Sending EAPOL-Key Message to mobile XX:XX:XX:XX:XX:XX
        state PTKINITNEGOTIATING (message 3), replay counter 00.00.00.00.00.00.00.01
*Dot1x_NW_MsgTask_0: May 23 12:04:11.186: XX:XX:XX:XX:XX:XX Received EAPOL-Key from mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:11.187: XX:XX:XX:XX:XX:XX Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:11.187: XX:XX:XX:XX:XX:XX Invalid RSN Descriptor code (254) from mobile XX:XX:XX:XX:XX:XX
*osapiBsnTimer: May 23 12:04:11.953: XX:XX:XX:XX:XX:XX 802.1x 'timeoutEvt' Timer expired for station XX:XX:XX:XX:XX:XX
*dot1xMsgTask: May 23 12:04:11.953: XX:XX:XX:XX:XX:XX Retransmit 1 of EAPOL-Key M3 (length 155) for mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:12.011: XX:XX:XX:XX:XX:XX Received EAPOL-Key from mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:12.011: XX:XX:XX:XX:XX:XX Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:12.011: XX:XX:XX:XX:XX:XX Invalid RSN Descriptor code (254) from mobile XX:XX:XX:XX:XX:XX
*osapiBsnTimer: May 23 12:04:12.953: XX:XX:XX:XX:XX:XX 802.1x 'timeoutEvt' Timer expired for station XX:XX:XX:XX:XX:XX
*dot1xMsgTask: May 23 12:04:12.953: XX:XX:XX:XX:XX:XX Retransmit 2 of EAPOL-Key M3 (length 155) for mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:13.011: XX:XX:XX:XX:XX:XX Received EAPOL-Key from mobile XX:XX:XX:XX:XX:XX
*Dot1x_NW_MsgTask_0: May 23 12:04:13.011: XX:XX:XX:XX:XX:XX Ignoring invalid EAPOL version (1) in EAPOL-key message from mobile 00:2
i have test command
config network ip-mac-binding disable
but It does not connect....
when I do the troubleshooting mac-client, the system always shows authentication error even though it is okay configured
1 REPLY
Community Member
I've been to analyze the problem and see that , CISCO WET200 our controllers do not support WPA2, gives errors procotolo authentication.
if I create a new wireless network using WEP or WPA has it all works.
strange?!?!
someone has the same problem??
I upgraded firmware and the problem continues
754
