Community Member
Error when installing webauth certificate virtual wireless LAN controller
Hi there
I am having issues installing web auth certificate for our virtual wirelesss LAN controller.
I am issuing a certificate from our own PKI in following format
device cert for WLC > Intermediate > our root cert.
I have followed the discussion here
and the document here
However I am still getting the following errors
*sshpmLscTask: Jun 30 17:18:26.443: sshpmLscTask: LSC Task received a message 4
*TransferTask: Jun 30 17:18:28.785: Memory overcommit policy changed from 0 to 1
*TransferTask: Jun 30 17:18:28.785: RESULT_STRING: FTP Webauth cert transfer starting.
*TransferTask: Jun 30 17:18:28.785: RESULT_CODE:1
*TransferTask: Jun 30 17:18:33.154: ftp operation returns 0
*TransferTask: Jun 30 17:18:33.154: RESULT_STRING: FTP receive complete... Installing Certificate.
*TransferTask: Jun 30 17:18:33.154: RESULT_CODE:13
*TransferTask: Jun 30 17:18:37.159: Adding cert (8217 bytes) with certificate key password.
*TransferTask: Jun 30 17:18:37.169: sshpmCheckWebauthCert: Verification return code: 1
*TransferTask: Jun 30 17:18:37.169: Verification result text: ok
*TransferTask: Jun 30 17:18:37.171: sshpmAddWebauthCert: Extracting private key from webauth cert and using bundled pkcs12 password.
*TransferTask: Jun 30 17:18:37.361: sshpmDecodePrivateKey: calling ssh_skb_decode()...
*TransferTask: Jun 30 17:18:37.493: sshpmDecodePrivateKey: SshPrivateKeyPtr after skb_decode: 0x2aaaacb51628
*TransferTask: Jun 30 17:18:37.493: sshpmAddWebauthCert: got private key; extracting certificate...
*TransferTask: Jun 30 17:18:37.494: sshpmAddWebauthCert: extracted binary cert; doing x509 decode
*TransferTask: Jun 30 17:18:37.494: sshpmAddWebauthCert: doing x509 decode for 1594 byte certificate...
*TransferTask: Jun 30 17:18:37.494: sshpmAddWebauthCert: failed to validate certificate...
*TransferTask: Jun 30 17:18:37.494: RESULT_STRING: Error installing certificate.
*TransferTask: Jun 30 17:18:37.495: RESULT_CODE:12
*TransferTask: Jun 30 17:18:37.495: Memory overcommit policy restored from 1 to 0
Any help is much appreciated
Everyone's tags (4)
Similar issue:https:/
Community Member
Hi Mohanak Thank you for the
Hi Mohanak
Thank you for the link unfortunately that is one of the links I have also read and followed by changing order of my certs in my PEM  from device cert > intermediate > root  to intermediate > device > root
This did not work
