Extend Guest SSID to other Controllers
Hi all,
Can I extend an SSID that I use for Guest access at central site to another controller at a remote site?
I have a 2112 WLC @ Central Offices with a Guest SSID that uses a Cable modem that provides internet to guest users, like a "hot spot". I want to "extend" that "hot spot" to branch sites without having to extend the VLAN that belongs to the guest SSID. The branch sites have 2112 WLCs as well and they are in a hub and spoke network to central site.
Can this be done?
1 REPLY
Hall of Fame Super Gold
Re: Extend Guest SSID to other Controllers
You sure can. Have you tried using H-REAP?
H-REAP Modes of Operation Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807cc3b8.shtml
H-REAP Design and Deployment Guide
http://www.cisco.com/en/US/products/ps6087/products_tech_note09186a0080736123.shtml
Hybrid Remote Edge Access Point (H-REAP) Basic Troubleshooting
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008081103d.shtml
Hope this helps.
446
