Failover WLSM configuration
Please help me in configuring redudency WLSM.
regards
srihari
Hall of Fame Super Red
Re: Failover WLSM configuration
Hi Srihari,
Here is some info to get you started;
Configuring WLSM Failover
From this good design doc;
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_implementation_design_guide09186a00807d592c.html#wp37405
Hope this helps!
Rob
Hi Rob,
Thank you for the response.
in our setup we dont have any tunnel. we purely use WLSM as WDS.
i am enclosnig my existing WLSM configuration
hostname WLSM-1
boot-start-marker
boot-end-marker
enable password xxx
spd headroom 512
aaa new-model
aaa group server radius cisco
aaa authentication login default group tacacs+ local
aaa authentication login infrastructure-authentication group radius
aaa authentication login client-authentication group radius
aaa authorization exec default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa session-id common
ip subnet-zero
ip tftp source-interface Ethernet0/0.7
wlan vlan 7
ipaddr 172.26.1.10 255.255.255.0
gateway 172.26.1.1
admin
standby 7 ip 172.26.1.1
username Cisco privilege 15 password xxx
no crypto isakmp enable
buffers huge size 46080
mac-address 000d.29f0.c7c6
no ip address
hold-queue 2048 in
encapsulation dot1Q 7
ip address 172.26.1.10 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.x.x.26.1.1
ip http server
no ip http secure-server
ip radius source-interface Ethernet0/0.7
snmp-server view iso iso included
snmp-server community readonly RO
snmp-server community readwrite RW
snmp-server system-shutdown
snmp-server enable traps tty
tacacs-server host 172.18.32.50 key 7
tacacs-server directed-request
radius-server host 172.18.32.50 auth-port 1645 acct-port 1646 key 7
control-plane
wlccp authentication-server infrastructure infrastructure-authentication
wlccp authentication-server client eap client-authentication
wlccp wds interface Ethernet0/0.7
wlccp wnm ip address 172.25.54.25
line con 0
stopbits 1
line 1 3
line vty 0 4
password 7
based on this could you guide me to to conigure redudency WLSM.
Srihari
147
