First Cisco AP config, not broadcasting SSID's
Below is the current config and for some reason it is not broadcasting SSID's (Office, Guest)
Any help is appreiciated.
Current configuration : 3833 bytes
! Last configuration change at 15:19:25 PST Tue Mar 2 1993 by pdx
version 15.2
no service pad
service password-encryption
hostname WR-AP
logging buffered 8192 informational
logging rate-limit console 9
enable secret 5 $1$KqEi$0zSi.Y1YMTaG00Z/UwWPW1
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PST -8 0
clock summer-time PDT recurring
no ip cef
dot11 syslog
dot11 vlan-name Default vlan 1
dot11 ssid Guest
   vlan 3
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 10691C4A160332080F013938
dot11 ssid Office
   vlan 1
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 1079580B561B41181F
dot11 guest
power inline negotiation injector 0001.e6d4.9c2b
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
load-interval 30
shutdown
encryption key 1 size 40bit 7 589A072FACD1 transmit-key
encryption mode wep mandatory
encryption vlan 1 mode ciphers aes-ccm tkip
encryption vlan 3 mode ciphers aes-ccm tkip
ssid Guest
ssid Office
antenna gain 0
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 spanning-disabled
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption key 1 size 40bit 7 7DF0BBE4F20D transmit-key
ssid Guest
ssid Office
antenna gain 0
peakdetect
dfs band 3 block
mbssid
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.3
no ip route-cache
bridge-group 3
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
ip address 10.10.1.253 255.255.255.0
no ip route-cache
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip default-gateway 10.10.1.254
ip forward-protocol nd
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
transport input all
sntp server 132.163.4.103
sntp server 192.43.244.18
end
1 ACCEPTED SOLUTION
in your config, the radios are still shutdown
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
D'oh!  I didn't even think of them as "interfaces" that need to be shut or no shut. (Again tis is my very first AP config that isn't lightweight mode.
Thanks for pointing out how stupid I was!!!
no ip address
no ip route-cache
load-interval 30
no shutdown
no ip address
no ip route-cache
no shutdown
266
