From DMZ to Internal network connection
Hi Guys,
My setup is I have 3 zones (External, Internal, DMZ) and traffic flow from all zones are ok. I am using Cisco ASA Software Version 8.2(1)
My laptop connected to Internal network and telnet to DMZ (natted ip) port 22 but fails.
Here is my packet tracer result. It drops under Phase 9, may I know if this is feature problem is ASA or have configuration need to change? Thanks
ASA# show int ip bri
Interface                  IP-Address      OK? Method Status                Protocol
Internal-Data0/0           unassigned      YES unset  up                    up
Internal-Data0/1           unassigned      YES unset  up                    up
Vlan11                     48.22.29.10     YES CONFIG up                    up
Vlan21                     192.168.25.254  YES CONFIG up                    up
Vlan31                     192.168.15.102  YES CONFIG up                    up
Vlan41                     192.168.10.254  YES CONFIG up                    up
Vlan991                    192.168.1.254   YES unset  up                    up
Virtual0                   127.0.0.1       YES unset  up                    up
Ethernet0/0                unassigned      YES unset  up                    up
Ethernet0/1                unassigned      YES unset  up                    up
Ethernet0/2                unassigned      YES unset  up                    up
Ethernet0/3                unassigned      YES unset  up                    up
Ethernet0/4                unassigned      YES unset  administratively down down
Ethernet0/5                unassigned      YES unset  up                    up
Ethernet0/6                unassigned      YES unset  administratively down down
Ethernet0/7                unassigned      YES unset  administratively down down
ASA#
ASA#
ASA# packet-tracer input DMZ tcp 48.22.29.10 22 192.168.15.101 22
Phase: 1
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Additional Information:
Found no matching flow, creating a new flow
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   192.168.15.0   255.255.255.0   internal
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group DMZ_access_in in interface DMZ
access-list DMZ_access_in extended permit object-group TCPUDP any any
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
Phase: 4
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: FOVER
Subtype: standby-update
Result: ALLOW
Config:
Phase: 6
Type: NAT-EXEMPT
Subtype:
Result: ALLOW
Config:
  match ip DMZ any internal 192.168.15.0 255.255.255.0
    NAT exempt
    translate_hits = 105470, untranslate_hits = 204
Phase: 7
Type: NAT
Subtype:
Result: ALLOW
Config:
nat (DMZ) 1 0.0.0.0 0.0.0.0
  match ip DMZ any internal any
    dynamic translation to pool 1 (No matching global)
    translate_hits = 14, untranslate_hits = 0
Phase: 8
Type: NAT
Subtype: host-limits
Result: ALLOW
Config:
  match ip DMZ any external any
    dynamic translation to pool 1 (48.22.29.10 [Interface PAT])
    translate_hits = 289676, untranslate_hits = 15395
Phase: 9
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat (internal) 1 0.0.0.0 0.0.0.0
  match ip internal any DMZ any
    translate_hits = 13, untranslate_hits = 0
Result:
input-interface: DMZ
input-status: up
input-line-status: up
output-interface: internal
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
ASA#
286
