Community Member
Full custom web page on WLC? Not possible?
Hello Guys!
I created a custom web authentication page, and successfully loaded this page on the WLC.
This is working fine
  • But ... when the user press "submit" button and authenticates, the "Default WLC Web Authentication" Pop-up shows up!  "You are now logged in now ... and so on".
  • And if you configure user policy, to let just one user to login at the same time, the second user fails to log in, and is redirected directly to the WLC's Internal Web Authentication page.
Is it possible to disable these pages?
Everyone's tags (6)
1 ACCEPTED SOLUTION
for the first issue.  did you copy in the java script from the test bundle?  Or you can pull it from the default page, right click, view source.  etc.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Community Member
Oh
I think I edited the main internal controller web page that's why.
By the way, Stephen, your answer was so fast! I am stunned!
you have to be fast around here, otherwise, Scott, George, Leo and Blake get all the answers.
HTH,
Steve
Hall of Fame Super Silver
Re: Full custom web page on WLC? Not possible?
Haha...
Scott Fella
Sent from my iPhone
-Scott
Community Member
Thanks, I will try to find where is a problem in that Javascript , why it tries to do bring up " successfull login" popup.
And what about second user, with username/password that's already in use? I can manage this to function properly too?
Silver
You could possibly do something with the return codes, look at the ksink example, to not show the login page again.
As for the popup, honestly, most everyone has popup blockers so they never see it anyways!
Is your wlc on version 7.2.103.0 by chance.
Scott Fella
Sent from my iPhone
-Scott
Community Member
Yes, WLC 2504 with this version of code.
We will use two of them ( one for redundancy, if a failure occurs anytime )
Yeah... The JavaScript has some issues. If you type in the credentials and you hit enter button, not the submit, does it default to the Cisco default login page?
Scott Fella
Sent from my iPhone
-Scott
Community Member
No, nothing happens
I can see this : when I am connected to the Access Point, and type the url ( www.google.com) I am redirected to the custom web authentication page, and to the internal authentication login page ( Because this internal page, I get an "succesfull login page" after login). ( Ofcourse at first, I can see just my custom page )
https://1.1.1.1/fs/customwebauth/login.html?switch_url=https://1.1.1.1/login.html&ap_mac=f4:ea:67:63:d9:00&client_mac=00:16:6f:24:94:7d&wlan=SSID&redirect=www.google.com/
This is what I was seeing on the 5508 running 7.2
When you hit the enter key, did you have your cursor in the password input field?
Can you attach your login.tar file?
-Scott
Community Member
ofcourse, there it is
Well that is an issue with the 7.2. You probably should open a tac case on that, because you shouldn't be redirected to the internal webauth page, and then if you just hit enter, you get redirected back to your custom page.
-Scott
Community Member
Hi guys,
I got some valuable information from cisco TAC today:
"After searching about the option that you want,  I found that the WLC 7.2.103.0 seems to have this new option at CLI:
(Cisco Controller) >config custom-web logout-popup ?
Enable/Disable the Web Authentication logout popup window.
But for versions before this, this feature was not supported."
You get any info on the redirect to the internal page?
Scott Fella
Sent from my iPhone
-Scott
Community Member
As they say, we can't fully disable internal web page right now
Community Member
works like a charm in 8.2.110
3082
