Full Encryption and WEP Bridges
ptuttle
Having problems getting 2 bridges to talk when enabling WEP with Full Encryption.
The bridges say they associate in the logs but under the IP address heading , it says "unassigned" and we cannot pass traffic at all to the other side.
We have entered the WEP keys several times, powered down the bridges.
As soon as we place them into "no encryption" everything works. But at that point we are not using WEP?
Any direction would be greatly appreciated
ptuttle@coghlin.com
murabi
Level 4
Level 4
Did you consider and follow all the steps mentioned at http://www.cisco.com/warp/public/102/wlan/connectivity.html#fourth
Thanks for the response.
I ended up opening a case with TAC and they said they have heard of this happening with 128 bit WEP keys. The solution is to open word pad and do a cut and paste of the WEP keys. I did this and it worked fine. I went back and manually entered the keys and the same problem. I manually entered these keys about 6 times and every time I did this it would fail. But if I did the cut and paste, everytthing worked fine.
-pat
we have the same problem, but the cut and paste solution doesn't solve our problem.
We loose connection after making a change at the configuration or rebooting the bridges!
What could be the problem??
It works after entering the wep key but, if we then make any changes the wep keys seem to be lost!
The same happens after rebooting!
