Community Member
Getting error about VLAN not existing on radio
When I try to enable the 5ghz radio on my AIR-AP1142N-A-K9 I get the following error:
VLAN '100' doesn't exist on 'Radio1-802.11N 5GHz' (see Services>VLAN)
In the vlan it is enabled.  What gives?
Config below:
version 12.4
no service pad
service password-encryption
hostname ap-1140-southwing
logging rate-limit console 9
enable secret xxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa group server radius rad_eap
server 192.168.1.187 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone CST -6
clock summer-time CDT recurring
dot11 syslog
dot11 vlan-name 5gwifi vlan 300
dot11 vlan-name jchcenterprise vlan 130
dot11 vlan-name public vlan 100
dot11 ssid jchccorp
   vlan 120
   authentication open
   authentication key-management wpa version 2
   mbssid guest-mode
   wpa-psk ascii 7 115A4A50461808040778797478
dot11 ssid jchcpublic
   vlan 100
   authentication open
   mbssid guest-mode
username Cisco password 7 10640C1C15435C5B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 120 mode ciphers aes-ccm tkip
encryption vlan 130 mode ciphers aes-ccm tkip
ssid jchccorp
ssid jchcpublic
antenna gain 0
mbssid
channel width 40-below
channel 2422
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.100
encapsulation dot1Q 100
no ip route-cache
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
bridge-group 100 spanning-disabled
interface Dot11Radio0.120
encapsulation dot1Q 120
no ip route-cache
bridge-group 120
bridge-group 120 subscriber-loop-control
bridge-group 120 block-unknown-source
no bridge-group 120 source-learning
no bridge-group 120 unicast-flooding
bridge-group 120 spanning-disabled
interface Dot11Radio0.130
encapsulation dot1Q 130
no ip route-cache
bridge-group 130
bridge-group 130 subscriber-loop-control
bridge-group 130 block-unknown-source
no bridge-group 130 source-learning
no bridge-group 130 unicast-flooding
bridge-group 130 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 300 mode ciphers aes-ccm tkip
ssid jchccorp
antenna gain 0
dfs band 3 block
mbssid
speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel width 40-above
channel 5180
station-role root
bridge-group 1
interface Dot11Radio1.100
no ip route-cache
bridge-group 100
interface Dot11Radio1.120
no ip route-cache
bridge-group 120
interface Dot11Radio1.300
encapsulation dot1Q 300
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
bridge-group 255 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.100
no ip route-cache
bridge-group 100
interface GigabitEthernet0.120
no ip route-cache
bridge-group 120
interface GigabitEthernet0.130
no ip route-cache
bridge-group 130
interface GigabitEthernet0.300
no ip route-cache
bridge-group 255
interface BVI1
ip address 192.168.1.195 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.35
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.1.187 auth-port 1812 acct-port 1813 key 7 002E161650155B
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
Everyone's tags (4)
Hall of Fame Super Silver
no ip address
no ip route-cache
encryption vlan 300 mode ciphers aes-ccm tkip <--should be vlan 100
Also since your using WPA version 2, don't use tkip
config t
no ip address
no ip route-cache
encryption vlan 120 mode ciphers aes-ccm!
encryption vlan 100 mode ciphers aes-ccm
no ip address
no ip route-cache
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
dot11 ssid jchccorp
   vlan 120
   authentication open
   mbssid guest-mode
   vlan 100
   authentication open
   mbssid guest-mode
You have 2 SSID's defined using vlan 120 and vlan 100, if you need another SSID, you need to define the vlan also.  If you just want jchcorp on the 5ghz:
no ip address
no ip route-cache
ssid jchccorp
no ip route-cache
bridge-group 100
no ip route-cache
bridge-group 120
Scott
-Scott
Re: Getting error about VLAN not existing on radio
Probably better to let us know what ssid's you want on what radio... you have defined vlan 300, but you don't have an ssid setup for vlan 300, then on your 5ghz, you only have one SSID, but then you have to vlans defined.  It's best to make changes on the CLI and not the gui also.
Scott
-Scott
Community Member
Sorry, posted in a hurry at end of day.
As far as using the CLI I don't know any of the commands.  Would need the beginner course there.
Need to add 5GHz to vlan100, the open network for visitors.
Any recomendations on a better way to best secure vlan 120 appreciated to.
I don't use vlan 300 anymore, need to delete them.
Thanks, Andy
Community Member
Anybody got more ideas?
You need to get familiar with the CLI. Here are some links.
https://supportforums.cisco.com/docs/DOC-16087
http://mrncciew.com/2012/10/24/multiple-ssid-config-on-autonomous-ap/
Configure WPA2/AES
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008054339e.shtml
-Scott
424
