Guest Access - using 2nd 4402 port not working
Hi All,
I have a 4402 behind our firewall acting as the anchor for our guest wireless and wired WLANs, the mobility tunnels work via holes through the firewall to port 1 on the WLC and then the traffic goes back out of port 1 to the firewall to get to the internet, no problems there.
I am now trying to get a third guest ssid working, but this time taking the Internet side of the traffic out of a second firewall which is connected to port 2 on the Anchor WLC. I can see the test client hitting the new firewall but the system seems to fail when the client tries to browse as the redirection to the web authentication page doesn't happen. If I point the ssid out of the WLC's port 1 it works straight away.
I really don;t know where to start looking to fault find, can anyone help?
Many Thanks
Scott
Hall of Fame Super Gold
Re: Guest Access - using 2nd 4402 port not working
Is Link AGgregation (LAG) enabled?  (Controller > General > LAG Mode on next reboot)
Hi Leo,
Thanks for the reply - LAG's disabled.
Scott
Hi Everyone,
I worked it out - turns out it was the external firewall had a reference to the wrong interface in the static translation (was a colleague that set that bit up, honest!) rather than anything to do with the WLC.
I used this document to help fault find....
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a0080a38c11.shtml
Scott
483
