Guest Controller
I am facing some problems with guest controller configuration. I have one local controller inside the network and one guest controller connected to the outside network. I will configure the dhcp pool in the guest controller. But the problem is that where will i define the guest vlan. i think we have to configure it in the pix. if we have to define it in the pix, we have to create the same interface on the local controiller also. could you please send me the pix configuration to achieve this.
1 REPLY
Silver
Re: Guest Controller
Yes you have to create the VLAN configuration in PIX. You can create the VLAN using the subinterfaces of the Ethernet interfaces of PIX.
The following URL helps you in configuring VLAN in PIX:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806ab788.shtml#conf
129
