Community Member
Guest WLAN and VLAN out of 2811 w WLC module
Using a WLC 2006 or 4000 series, there is
no problem getting the traffic on a "guest WLAN" connected to a wired VLAN.
But, how to do that when one is using
a 2811 with a WLC module?
Now the "guest WLAN" connects internally
to the 2811 "interface wlan-controller 1/0" as a VLAN on a subinterface. I do not want the default GW for that VLAN within the 2811. Instead I just want to get it out at layer 2. Transparent bridging between a subinterface "int wlan-controller1/0.x" and "int fastethernet0/1.x" failed. Any ideas?
1 REPLY
133
