09-13-2013 12:59 PM - edited 07-04-2021 12:50 AM
Hello Guys, please someone help me.
I can't access the gui from cisco WLC 2100 device, i changed IP's to the same subnet, connected straight-through cable on both interfaces (Notebook & WLC), i can ping, but can't access the GUI by using ethernet connection.
I've tried to access the GUI using WI-FI and it worked perfectly, but i still can't access using ethernet, please give me advices!
Is there a way to upgrade WLC IOS using wireless?
Thx
09-13-2013 01:39 PM
Go to console of the WLC & post "show interface detail management" output. In WLC Which ports connect back to switch & what is the switch port configuration looks like ?
In the switch, post "show run interface x/x" where x/x is connecting to your 2106.
Rasika
09-16-2013 09:35 AM
Hello Rasika, thanks for answer.
I've solved the issue after a reboot. I don't know what happened, but is working now. Thanks for advice.
09-16-2013 01:33 PM
Ip of interface is changed at OS level, but running processes (like web gui) don't know untill restart controller.
