H-REAP Lap Configuration Wrong Vlan Wrong Bridge Group
I'm trying to configure our access points as H-REAP. I have gone over this document many times and I cannot figure out what I'm doing wrong. I noticed now that when I telnet into the any of the access points they are configured very wrong.
It configures the Gigabit Interface correctly but not the radio interfaces. For some reason it's always using sub interface 0.17???
And it's configuring radius and eap-fast options, when I don't have it enabled...
interface Dot11Radio0
no ip route-cache
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
bridge-group 254 spanning-disabled
interface Dot11Radio0.17
encapsulation dot1Q 17 native
no ip route-cache
bridge-group 255
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
bridge-group 255 spanning-disabled
interface Dot11Radio1
no ip route-cache
interface Dot11Radio1.2
no ip route-cache
bridge-group 254
interface Dot11Radio1.17
no ip route-cache
bridge-group 255
interface GigabitEthernet0
ip address dhcp client-id GigabitEthernet0
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.200
encapsulation dot1Q 200
no ip route-cache
bridge-group 200
no bridge-group 200 source-learning
bridge-group 200 spanning-disabled
interface GigabitEthernet0.500
encapsulation dot1Q 500
no ip route-cache
bridge-group 254
interface GigabitEthernet0.1200
encapsulation dot1Q 1200 native
no ip route-cache
bridge-group 255
ip http server
logging trap errors
logging origin-id string AP:0022.bd19.8ab0
logging snmp-trap notifications
logging snmp-trap informational
logging snmp-trap debugging
logging 255.255.255.255
radius-server local
no authentication eapfast
no authentication leap
no authentication mac
eapfast authority id 436973636F0000XXXXXXXXXXXXXXXXXXX
eapfast authority info Cisco A_ID
eapfast server-key primary 7 5267636E4XXXXXXXXXXXXXXXXXXXX
nas 10.0.200.15 key 7 083544471A101618XXXXXXXXXXXXXXXX
nas 10.0.200.16 key 7 105A0110161E01040XXXXXXXXXXXXXXX
group hreap
radius-server host 10.0.200.16 auth-port 1812 acct-port 1646 key 7 xxxx
Re: H-REAP Lap Configuration Wrong Vlan Wrong Bridge Group
The whole idea of H-REAP APs is to support tagged VLAN access centrally and/or locally. This is an improvement upon the REAP 1030 APs, which only supported native VLAN traffic. This AP needs to be connected to a trunk port on the switch. Whichever WLANs you select on the controller for local switching will bridge the traffic to the switch it's connected to. I guess I haven't paid that close attention to the per-AP config, but it would make sense to me that you would see a difference in the config of the sub interface on the radios and the gigabit interface depending on which SSIDs are configured for local vs central switching. I would think that any SSIDs configured for central switching would just bridge through the native VLAN b/c they're going to be tunneled, and you therefore wouldn't see that tag added to the gigabit interface. Then you would see a tag added to the gigabit interface for any VLANs that are to be switched locally.
Silver
What exactly is the problem? What configuration do you have for the hreap/vlan mappings?
VLAN 17 is used on the radio for the native vlan on the radio, and typically each other vlan you map will bridge to vlans 1,2,3,4,etc... up to 16 (as 16 should be the maximum number of SSIDs on a radio)
Anyhow, your do0.2 is bridged to vlan 500, and your do0.17 is bridged to the native vlan of 1200.
I guess the thing to remember is that the vlans on the Radios are different than the vlans on the ethernet interfaces.
I can't answer for the radius configuration.... nor can I answer for why you have a vlan 200 with no radio tied to it.
What version of code is this?
Ok, here is the problem explained:
I have setup a new 5508 controller with the latest code and (for right now) one access point in H-Reap mode for switching on a local network. This access point is setup with one ssid which is mapped to a vlan on the local switch that is its connected to in trunk mode. What happens is if i'm using an ssid in wpa or wpa2, tkip, aes or any combination the client cannot authenticate to the ap if*** the ap has a connection to the controller. If*** the ap looses connection to the controller, as if a link between them has gone down, then the access point allows the client to authenticate.
If the ssid is set to open or wep all is well if the ap has a connection or not.
I have had tac look at it and they see no configuration problem with h-reap, vlan mappings or the switch configuration. So for right now i'm waiting on them to re-create the problem in the lab.
Ok, that make sense on how it uses different vlans on the radios. I figured out the radius configuration...i had tried creating h-reap groups...so i removed that.
345
