Hi,all
my problem is like this:
A router with IOS FW feature set is installed in my office.For internet access use,I implement NAT for LAN users:assigning a public IP correspondind to a scope of private ip for "overload".But I tracked suspected sessions when I use "Show ip nat translation":an unallocated public IP is being used for the NAT mapping!Meanwhile,the allocated IP is also being used for outside DNS resolution.
I'm confused about it!So I disable all outbound IP trafffic for the unallocated IP by using "Access-list".But the problem is still in persistence.
Could anyone instuct me on what's wrong with my router?Thanks!
