Help with autonomous wireless access point, dot1x and guest VLAN
Please can someone help with this as I'm tearing my hair out!
Hardware: Cisco 3750 switch and Cisco autonomous access point (AIR-AP1142N-E-K9).
Requirement: A single broadcast SSID; use dot1x to assign vlan 98 to authenticated clients (computer certificate); assign vlan 3 (guest) if the authentication fails.
I can achieve assigning a guest vlan on authentication failure when using a wired connection by using the following command on the interface:
authentication event fail action authorize vlan 3
I'm after a way to achieve the above using the wireless access point.
The main point is that internal users cannot access vlan 3 as they have a valid certificate and that guests do not have to authenticate.
Many thanks in advance
Re: Help with autonomous wireless access point, dot1x and guest
Well, if you have ACS 5.x as radius you can configure policies so that assign vlan x for succeeded clients and vlan y for failed clients. I dont think what you eant is available from AP side configuration.
Rating useful replies is more useful than saying "Thank you"
unfortunately you cannot do this.
Since the (necessary) WPA(2) key handshake relies on a successful authentication, there is no such thing like a auth-failed vlan when doing wireless. Usually people work around that using a dedicated guest SSID.
regards
Stefan
818
