How many SNMP Hosts can I configure on switches & routers?
Hello everyone!
Simple question.  How many SNMP hosts can I configure on my switches and routers?  I was asked this question and began doing some research but perhaps I'm overlooking it.  So, can I send SNMP traps to more than one host?  Thanks!
Terence
VIP Purple
Hi Terence,
Definetely you can send it to multiple hosts by using "snmp-server host command.
I do not know about any max number of limit. If you configure this commands with different IP addresses then you can find out if there is any limit.
Rasika
Bronze
Maximum number of hosts
While collectd and the SNMP plugin don't have any limitation on the number of hosts you can configure, the library used by the SNMP plugin, libnetsnmp, uses the select(2) system call. This system call uses a fixed-size bitfield to hold file descriptors. On many systems this limits the number of hosts you can query with the SNMP plugin to 1024 (for example when using the GNU libc).
To solve this issue, the netsnmp library must be changed. A solution would be to switch to the poll(2) system call which doesn't have a static limit on the largest file descriptor it can handle.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/sm_snmp.html
VIP Purple
Re: How many SNMP Hosts can I configure on switches & routers?
HI Ageel
Thanks for giving useful information on this +5
Does the provided URL give any information of how to change these.. I could not find it
Rasika
760
