How to configure wireless Cisco 1041/EAP2 with Radius
Having trouble configuring wireless on a Cisco 1041 with a 2012 Radius Server
I have a cisco ASA 5505 and Windows server 2012 Radius with NAP and Network Security policy
Guest Test guest works, test does not, I want the users to log into test with their AD credentials
Here is the AP config:
Thanks for any help
o service pad
service password-encryption
hostname ap1
logging rate-limit console 9
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap2
server x.x.x.x auth-port 1645 acct-port 1646
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods2 group rad_eap2
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
clock timezone -0500 -5
clock summer-time -0400 recurring
ip domain name ser.local
dot11 syslog
dot11 ssid test
   vlan 1
   authentication open eap eap_methods2
   authentication network-eap eap_methods2
   authentication key-management wpa
   mbssid guest-mode
dot11 ssid test guest
   vlan 12
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7
dot11 priority-map avvid
dot11 phone dot11e
power inline negotiation injector 001b.8fac.990a
power inline negotiation prestandard source
class-map match-all _class_data_policy0
match ip dscp default
class-map match-all _class_voice_policy0
match ip dscp ef
policy-map voice_policy
class _class_voice_policy0
  set cos 6
policy-map data_policy
class _class_data_policy0
  set cos 0
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers aes-ccm
encryption vlan 12 mode ciphers aes-ccm
ssid ihiCorp
ssid ihiGuest
antenna gain 0
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
service-policy input data_policy
service-policy output data_policy
interface Dot11Radio0.12
encapsulation dot1Q 12
no ip route-cache
bridge-group 12
bridge-group 12 subscriber-loop-control
bridge-group 12 block-unknown-source
no bridge-group 12 source-learning
no bridge-group 12 unicast-flooding
bridge-group 12 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.12
no ip route-cache
bridge-group 12
interface BVI1
ip address x.x.x.x 255.255.255.0
no ip route-cache
ip default-gateway x.x.x.x
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host x.x.x.x auth-port 1645 acct-port 1646 key 7
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
1 ACCEPTED SOLUTION
on teh laptop, go to Start > Run and type in mmc.
Add remove snap-in for Certificates, Computer account should be fine.  In there you'll see Root Trust and Enterprise root Trust.  Make sure the Root CA is listed in one of those areas.
You should be able to push that cert out via GPO, so long as the computers are on the wire first
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
with radius debug on, on the AP I fet these error messages:
RADIUS/DECODE: EAP-Message fragments, 4, total 4 bytes
*Sep 12 20:40:14.341: %DOT11-7-AUTH_FAILED: Station
RADIUS:  EAP-Message         [79]  6
ADIUS:  Message-Authenticato[80]  18
EAP-Message         [79]  6
So, the config looks right from the group mapping perspective, though "authentication network-eap eap_methods2" would be used for LEAP.  PEAP or TLS will use "authentication open eap eap_methods2"
you can take a look at the below on some commands you can use to test the AAA from the CLI
https://supportforums.cisco.com/docs/DOC-22169
Do you know if the NPS is configured to listen on 1645/1646?  It may only be set to use 1812/1813
HTH,
Steve
where can I check the NPS port setting (Server 2012) ?
Thanks for the reply
it is set to use
1812,1645- authentication
1813,1646 -accounting
ok, when you check the systems log for the timeframe the user tried to get on, do you see any messages?
HTH,
Steve
I was checing the logs earlier, did not see anything will check again now
I get these messages:
A fatal alert was received from the remote endpoint. The TLS protocol defined fatal alert code is 48.
from source schannel
A LDAP connection with domain controller IHIserver01.ihi-press.local for domain TEST is established.(from source NPS)
in order I get these messages;
The processing of Group Policy failed. Windows attempted to read the file \\test.local\sysvol\test.local\Policies\{31B2F340-016D-11D2-945F-00C04FB984F9}\gpt.ini from a domain controller and was not successful. Group Policy settings may not be applied until this event is resolved. This issue may be transient and could be caused by one or more of the following:
a) Name Resolution/Network Connectivity to the current domain controller.
b) File Replication Service Latency (a file created on another domain controller has not replicated to the current domain controller).
c) The Distributed File System (DFS) client has been disabled.
Alert code 48 is unknown CA
http://blogs.msdn.com/b/kaushal/archive/2012/10/06/ssl-tls-alert-protocol-amp-the-alert-codes.aspx
So you are doing EAP-TLS, does the end machine have the Root CA in it's trust list?
HTH,
Steve
Sorry, How do I check ?
HTH,
Steve
Thanks alot !!!!!!!!!!!
1119
