Community Member
How to create a truly open wireless network on CT5760 controller?
We have a 5760 setup and a mix of 3702 and 1142 access point.
But, no matter what I do, I can't create a really 'open' network... I mean a non-restricted, open wireless network. Like what you get when you buy a home 50$ access point.
Even after disabling all restriction, clients still can't connect directly to one another.
I need to create this SSID for an experiment in one of our labs and they want all their options open... including multicast...
So, my question is: Can I make a super smart network setup to do a simple wireless network?
Thanks guys!
P.S
I can't use any other equipment from various reasons... must do it with what I have...
Everyone's tags (1)
VIP Purple
HiHere is an example for Open
Here is an example for Open Auth SSID (named OPEN & WLAN-ID 2) configuration.
wlan OPEN 2 OPEN
 client vlan x
 no security wpa
 no security wpa akm dot1x
 no security wpa wpa2
 no security wpa wpa2 ciphers aes
 no shutdown
ip dhcp snooping
ip dhcp snooping vlan x
You need to make sure your 5760 is have basic configuration to have the proper network connectivity.
http://mrncciew.com/2013/12/12/getting-started-with-5760/
Here is a sample WLAN config on 3850 (applicable to 5760 as well)
http://mrncciew.com/2013/12/04/wlan-config-in-3850-part-1/
http://mrncciew.com/2013/12/06/wlan-config-with-3850-part-2/
Rasika
**** Pls rate all useful responses ****
Refer the link for Open
Community Member
Hi all,I tried your
Hi all,
I tried your suggestions but unfortunately it is not working... after associating two clients to that SSID, they can't reach each other by PING. (which worked when both were connected to a simple home router).
This is the wlan config:
wlan naor 100 naor
 accounting-list
 no assisted-roaming dual-list
 no assisted-roaming neighbor-list
 band-select
 broadcast-ssid
 ccx aironet-iesupport
 channel-scan defer-priority 4
 channel-scan defer-priority 5
 channel-scan defer-priority 6
 channel-scan defer-time 100
 chd
 client association limit ap 0
 client association limit radio 0
 client association limit 0
 client vlan 4000
 dtim dot11 24ghz 1
 dtim dot11 5ghz 1
 exclusionlist
 exclusionlist timeout 60
 ip access-group web
 ip access-group
 ip dhcp server 0.0.0.0
 ipv6 traffic-filter web none
 ipv6 traffic-filter none
 load-balance
 mac-filtering
 mfp client
 mfp infrastructure-protection
 mobility anchor sticky
 radio all
 no security wpa
 security dot1x authentication-list
 security dot1x encryption 104
 security ft over-the-ds
 security ft reassociation-timeout 20
 security pmf association-comeback 1
 security pmf saquery-retry-time 200
 security static-wep-key authentication open
 security tkip hold-down 60
 security web-auth authentication-list
 security web-auth parameter-map
 service-policy client input unknown
 service-policy client output unknown
 service-policy input unknown
 service-policy output unknown
 session-timeout 1800
 wmm allowed
 no shutdown
It id quit frustrating...
Thanks for the help!
VIP Purple
Pls post output of the below
Pls post output of the below commands
1. show run | sec wlan naor
2. show wlan id 100 | in Peer
Rasika
Community Member
Hi, thanks for the prompt
Hi, thanks for the prompt reply... this is the requested info:
WLC5760-WICC#show run | sec wlan naor
wlan naor 100 naor
 band-select
 client vlan 4000
 load-balance
 no security wpa
 no shutdown
WLC5760-WICC#
WLC5760-WICC#show wlan id 100 | in Peer
Peer-to-Peer Blocking Action                   : Disabled
WLC5760-WICC#
154
